Ga door naar hoofdinhoud
Released in April 2012 by Garmin. The Garmin Nuvi 2595LMT has a 5" (12.7cm) touchscreen and voice-activated navigation.
How do I remove the Digitizer from the LCD Screen?
I have a broken digitizer on my Garmin Nuvi and when I follow the disassembly guide, I can't figure out how to separate the digitizer from the LCD Screen. There aren't any screws, so how would I remove it? Can I even remove it?
Is dit een goede vraag?
Score 3
1 Opmerking:
It works but the screen needs replaced do you have a screen?
door
Voeg een opmerking toe
1 Antwoord
Hi Taylor, that is a great question. We have a digitizer replacement guide available here.
To answer your question, you need to use a metal spudger from the Ifixit Pro Tech Toolkit or other flat headed tool to gently pry the sides of the digitizer until it lifts open and separates from the LCD Screen.
I hope this helps you with your project.
- Mary
Was dit antwoord nuttig?
Voeg je antwoord toe
Taylor DeWitt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 628
