Ga door naar hoofdinhoud
De G4 Quicksilver werd uitgebracht met snelheden van 533 MHz, 667 MHz, 733 MHz, 800 MHz, 933 MHz en 1,0 GHz.
Pressing power button does not turn on
Pressing the power button, Unit does not turn on. Button lights up for a split second, drive does not turnover. Disconnecting power cord and reconnecting does not help. Is the problem the power button or the drive?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It's probably the power supply. Do you get any diagnostic lights on the logic board?
UPDATE 2/26/16
The diagnostic LEDs should lit up when you press the power on button if the power supply is good.
There is also a CUDA logic board reset button on the logic board. Press the CUDA button, ONCE! It is located to the rear of the battery housing. It looks like a small pencil eraser in a metal square..
Have you replaced the 3.6V/850mAh 1/2 "AA" Lithium PRAM battery?
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I will check. Will lights be present on the logic board with plug connected and the unit powered off though?
door
Did you ever fix it?
door
Voeg je antwoord toe
Mik B zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,152
