Ga door naar hoofdinhoud
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
435 Vragen Bekijk alle
Tip of Lightningcable broken and stuck in the Ipad...
Worst case cenario? While loading my Ipad Air 2 it fell from the desk directly on the lightningconnector with the cable in it. The tip of the cable broke and is now stuck in the lightningconnector - so far no way of getting it out, even the repair shop didnt manage.
If they open it and try to repair/exchange the lightningsocket (or whatever its called) apple warranty is void. (Ipad is just about 2 month old)
Now on the other hand apple probably wont repair but just offre an replacement for unbelievable 380 €!!!! 380 € because a loading cable broke!!!! And apple build this thing in a way thats a) hypersensitive and b) refuse to repair it!
I really hope anybody here has got a better idea?
thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
You may want to try another repair shop. So far, I have always been able to remove broken lightning tips. I use a microscope and dental probes, and it works great.
Was dit antwoord nuttig?
Score 2
Could you post a picture please?
Score 1
Dear David, Dear Chris
thanks for your quick replys.
here is the best picture I could take so far:
the aluminium shell is bend upwards, the socket itself seems ok, but can´t say for sure.
David, I thought about using a very fine drill to either break the lightningcable tip to pieces that I can get out with a fine brush or vaccumcleaner or - better - have the drill stuck in the tip so I can pull it out?
otherwise i thought about using several small plastic pipes and inject a strong glue through them, so I can glue them to the tip and pull it out? otherwise I might try with a shop that´s repairing clocks or other fine mechanics?
thanks for your help!
best
benjamin
Voeg je antwoord toe
caspar georg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 93
