After screen replacement touch screen problems
Well i swapped out the old cracked screen and inserted a new one.
It worked up to a point. That being the right hand side of the touchscreen didnt't respond. Also on that side there was a fuzzy yellow spot.
So i put up with it for a while then yesterday opened it up again, took out the flex cables and reinserted them.
After that it was worse than before. Now the screen has lines and virtually no response to touch and it does random things.
I didn't turn the phone off during the repair so would that have caused anything?
Also, in the process i have lost one of the screws, namely the bottom left corner screw which hold the square plate down onto the cables.
Today i tried disconnecting the battery but that failed to make a difference.
Also tried a hard reset via iTunes but came back with error 1661 - a hardware problem was encountered.
Does anybody have any good suggestions?
Is dit een goede vraag?
