Ga door naar hoofdinhoud
Battery operated Thomas the Tank Engine ride-on train with track.
20 Vragen Bekijk alle
Can't get drive motor to work
Hello, we have had the above toy given to us from a friend, but although battery was charged overnight, I can only get toy to play the music and noises. Even when on the track? I am more than happy to get new battery, if this may be the fault, but could there be a motor problem? Toy does not appear damaged in any way, and was assured it worked fine when it was given to us. Can the battery get so worn out that it will hold voltage to make noises but not enough power to turn wheels ??
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Your last question is very valid and yes that is very probable. If it's been a year or two on that battery ,then it's probably time. To be sure , get a small volt meter and see how many volts the battery has after charge. You can get a little more life out of it if you drain the battery alllll the way down. It might last a time or two or so but good luck . Oh motors are generally fused so it is possible you could have just blown one. Just trace wire down to find , Good Luck.
Was dit antwoord nuttig?
Having same problem. When I wire the battery directly to the derive motor, the train moves. I'm told it's the circuit board (meva0024). Does anyone know where to get an inexpensive one? They are listed on some sites for $19.95 but unavailable. I'm not giving Peg Perego $60.00- $70.00 for it.
Thanks for your help.
Hello, I remove the battery from thomas the train to charge. I'm having the same problem thomas doesn't move but the music does play even after I removed the battery.
Voeg je antwoord toe
neathmad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 3,141
