Ga door naar hoofdinhoud
The iRobot Roomba 560, an automated vacuum cleaner, was released in 2009.
14 Vragen Bekijk alle
Access to Roomba 560 circuit board.
I have a faulty Roomba 560. afer substitution teting I gather the problem is in the board.
I suspect the problem may be in some capacitor as the problem is intermitent but recurring.
simple screw driver dismantling left me short of the pcb.
Where can I find instructions to access the pcb?
Is dit een goede vraag?
Score 1
2 opmerkingen
Did you try to find solution from irobot customer care? I think you should not fix roomba by yourself, it's still a high tech machine anyway
door
Oh, try to find answers form other sites like http://irobotroombareviews.com/ I've just catched it last week and it's quite useful
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi, Here's a link to the service manual. Hope it helps.
http://choisirsonaspirateur.info/wp-cont...
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
+ research
door
Thanks, most useful info
door
Het nuttigste antwoord
I had a similar problem, but had to replace some sensors on the board. Looked all over for a fix. Found an affordable one that worked well. took an hour or so.
http://eesolutions.ca/roomba_repair_kit....
I'd recommend it. Took forever to find the site though.
Score 5
Hi.
Here is quick fix for your roomba.
http://www.abstractpath.com/2008/fixing-...
Cheers
Voeg je antwoord toe
Axel Brinck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 16
Altijd: 13,292
