Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
iPhone 1G front panel kit
change iPhone 1G front panel kit
I need that part, and I can't find it on iFixit. It used to be there 3 days ago. Can you help me with the link on iFixit?
Update
Are the 1st gen digitizers the same as the 3G digitizers?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
the digitizer for the 1st generation iphone is connected directly to the lcd screen as well. so its like a combo screen. its not compatible with 2g or 3g because it has different connectors
Was dit antwoord nuttig?
Score 3
These are all the parts that are available for purchase for the 1st generation iPhone.
As Alex mentioned, the 3G digitizer is not compatible with the 1st generation. Further complicating things, the opening procedure for the phone is very difficult, so you should definitely read through the guide before attempting to replace the display assembly.
Score 2
if the link is gone, it means they run out. its gone mate...
Score 1
1 Opmerking:
door
i need a front panel for a i phone 1g and a repair kit fot it to
Voeg je antwoord toe
Sameh Mousa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 11,312
