Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Stuck in a reboot loop after repair
I put a new frame on my iPhone 5s and put it all back together. I had it working except the screen didn't want to rotate so I took the front screen of again to try to solve these problems. I reconnected the LCD cables and home button and now I am stuck in a reboot loop, and my screen has a horrible line down the middle. I have had this problem before and I figured out it was just the screws being in the wrong holes on the LCD cable shield. I had the screws in the right holes but yet I am still in a boot loop. I currently have the shield remove from my iphone and it's still in a boot loop and it won't restore on iTunes. I have also tried Reiboot and it didn't work. On iTunes I keep getting Error 9 or the device can not be found. Please help!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I would remove all the screws from the board to see if something is causing a short or flexing it. Can you test the device with a different screen?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I do not have a different screen to try but I will try to remove some screws
door
Voeg je antwoord toe
beeweezy18 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 129
