Ga door naar hoofdinhoud
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Vragen Bekijk alle
Logic board part number
Hello!
I have a late 2011 unibody MB Pro, 15", part number A1286. I believe the GPU on the logic board died - blue screen with vertical lines galore.
I want to attempt and replace the logic board but am not sure of the part number. The SN of the unit is C02HL7LZDV7L and I think the proper PN for the board is 661-6081 but would like confirmation.
Thanks!
Update (02/01/2016)
Isn't the SN C02HL7LZDV7L?
The sticker on the RAM slot says the following:
SN: C02HL7LZDV7L
MLB No: C02215200PGF16HA4
EMC No: 2563
Thanks.
Is dit een goede vraag?
Score 1
4 opmerkingen
Give us the full systems serial number so we can cross check what you have.
door
Dan where are you going to check serials now where I've always gone is being flagged her as spam
door
@jimfixer - Here: EveryMac and my Apple Service Account ;-}
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There were actually 2 revisions for this board
661-6081 Board, Logic, 2.2 GHz, Core i7, Rev 1
661-6160 Board, Logic, 2.2 GHz, Core i7, Rev 2
Hope this helps
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
Thanks! Do you know if the hardware is the same in terms of mounting points and hardware hookups?
door
doing a little more checking and will let you know
door
From what I've been able to gleen there are actually 3 boards that are compatible with your situation 661-5852, 661-6081, 661-6160 There all supposed to be interchangeable . The 5852 was never sent from the factory with this computer but it will work in a pinch. Take this with a grain of salt as I was only able to confirm this from 2 sources
door
Thanks! All of these are such mad bank :'(
door
all Mac boards are
door
1 commentaar meer tonen
Het nuttigste antwoord
Take it in to an Authorized Service Provider and ask them to test it for this repair:
https://www.apple.com/support/macbookpro...
MacBook Pro Repair Extension Program for Video Issues
Apple has determined that a small percentage of MacBook Pro systems may exhibit distorted video, no video, or unexpected system restarts. These MacBook Pro systems were sold between February 2011 and December 2013.
Apple or an Apple Authorized Service Provider will repair affected MacBook Pro systems, free of charge. See below for details on affected models and service options.
Symptoms
An affected MacBook Pro may display one or more of the following symptoms:
Distorted or scrambled video on the computer screen
No video on the computer screen (or external display) even though the computer is on
Computer restarts unexpectedly
Products affected
15-inch and 17-inch MacBook Pro models manufactured in 2011
15-inch MacBook Pro with Retina models manufactured from Mid 2012 to Early 2013
Do not use the identify your coverage from this site as it only tells you about your original warranty, not the program.
Score 3
Voeg je antwoord toe
Gene zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,674
