Ga door naar hoofdinhoud
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Screen is not as bright
I had to replace my complete screen ( touch digitizer and LCD screen).I. put it back together and it came on but noticed screen was not as bright even though brightness controlled all the way up.If I put it on auto bright you can barely seen the screen. I doubled check the LCD ribbon and seem to be in good. Any ideas on what could be the problem.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Not sure who you got your screen from but sometimes there's a protective film on the screen that's tinted you need to peel off. Ive made that mistake once myself.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
No I removed that
door
My screeen became dim after I upgraded to 10.1
door
@rouadi1 In your case I would check my settings in power settings and in the display settings. Sometimes upgrades change default settings
door
Its your front camera flex cable (there is proxy on it) and this proxy didnt recognize light propertly
Score 1
Voeg je antwoord toe
Arletta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,665
