Ga door naar hoofdinhoud
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Vragen Bekijk alle
Stylus is stuck in phone. It was NOT put in backwards.
I cannot remove the stylus from my phone. When trying to find solution online, they were all directed to issues where the stylus was put in backwards. This is NOT the casr here. Stylus appears to be in too deeply. How can I remove ot?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Pry it out. Try using a flat heat screw driver, or a needle nose plyers, if you can
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
33isadora zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 735
