Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Why is my screen red?
I left my iPhone 5s in my room and when i got back the screen was red with black lines in the middle. But the sound and the touch both work. For example i can type in my password and i can go in any app that i want but i just can't see the screen i press by guess. what should I do?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I think it is the proximity camera flex,
First of all hold power and home button for 15 seconds to reset.
If this still persists:
Open up the iPhone and disconnect the 3 flex cables from the motherboard, re-sit them and then turn your phone on again.
hope this helps.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Had the same issue with a phone I was repairing. There was severe damage to the upper portion of the screen assembly, which had apparently caused damage to the proximity/front facing camera flex cable (this component also contains a microphone, background sound sensor, and the earpiece speaker contacts). Replaced the component and the phone worked fine.
Replacement of most embedded components requires some level of skilled labor. Disassembling a device may void or limit the manufacturer's warranty. Any advice provided are to assist in the end user repair of their device. Improper or inexperienced repair can lead to damage to device or injury to user.
door
Voeg je antwoord toe
parmis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 121
