Ga door naar hoofdinhoud
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
52 Vragen Bekijk alle
Why does my engine rev sometimes when idling?
When my foot isn't on the gas and the car is not in gear (it has a manual transmission), the engine will do short revs every 1 or 2 seconds. Any idea what this could be? The car also has a blown head gasket. Could that have been the problem? It's in the shop right now getting repaired for that, so we'll see if the problem goes away after we fix that.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The head gasket is most likely the problem, this can cause poor compression, hence the reving
Was dit antwoord nuttig?
Score 3
1 Opmerking:
I know this was from almost a year ago, but I figured I'd add that we got the head gasket replaced and it fixed the problem. Thanks!
door
It also could be your IACV or your FITV
Score 1
Voeg je antwoord toe
Sterling Hirsh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 12
Altijd: 2,329
