Ga door naar hoofdinhoud
Vraag afgerond
Can I upgrade my memory to something more than 6 GB?
Hi everyone, I have a Toshiba Satellite L755 PSK2YE-0KW00YFR as you can clearly see in the description and i have 6 GB of memory, 4 GB in one slot and 2 GB in the other, my question is, can i expand my memory to more than that ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The Satellite L755-S5173 has 4 GB of memory (RAM), which is the minimum required to handle the workload of the average user using modern applications. If you find it slowing down when multiple windows are open, consider buying more RAM, as the memory is expandable up to 8 GB. There may also be other models of this laptop that come with the full 8 GB.
http://laptops.specout.com/l/724/Satelli...
Was dit antwoord nuttig?
Score 4
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 145
