Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
iPhone 5s slowly charging and fast battery drain
Hi,
i got an iphone 5s which is charging very slow and fast battery drain.
It doesn't matter if the phone is in flight mode or not.
I think, it is an IC problem.
Does anybody knows, which IC is causing this problem?
Power Management Control IC PM8018 or
Power Management IC 338S1216 or
U2 IC 1610?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
More than likely the U2 IC that is damaged, as this chip is damaged easily with copy chargers etc.
This causes things like fast battery drain (even in airplane mode)
Overheating
And a few other symptoms.
Replace that and see what results you get. :-)
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
where is the u2IC CHIP LOCATED, WHAT PART DO I NEED TO REPLACE
door
There are plenty of schematics available online, depends which iPhone.
door
Try replacing the battery
Replace the battery is the first step to do.
Then, if still not working, should be IC or water damage.
Voeg je antwoord toe
christian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,586
