Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1022 Vragen Bekijk alle
Is it bad to use my iPhone while its charging?
I like to use Oovoo, Skype, Instagram, Snapchat, Twitter, and Youtube while it is charging. And I've always heard from most of my friends that its bad and can cause
the iPhone to die faster than usual. Is that true?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Yeah, it's not very good for your phone. Especially the battery and the U2IC
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
What's the U2IC?
door
It's a chip on the logic board that helps the power from your charger get to the battery
door
Het nuttigste antwoord
This is totally normal, why do you even buy the thing if you don't use it?
Score 2
I've used plenty of apps on my phone while it was charging for well over a year now and I've had no issues. The only thing which will be different is that the phone will charge more slowly, because you are doing things on the phone which require power too. If you want to quickly charge your phone, it is best to completely shut it down and then plug it into the charger. However, if you want to use the phone while it's plugged in, there will be no issues.
Voeg je antwoord toe
carlito zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,494
