Why does my insignia flex 7 NOT charging?
i inserted my charger into the port, but it won't charge my tablet. I may have inserted the charger the wrong way, so it damaged the port. How do I replace it.
Is dit een goede vraag?
sometimes if you do not use the original charger and cord then the device will not get enough amperage to charge. i have had this happen with many tablets. also sometimes it can be the charger part is messed up or lose and finally the battery could just be messed up. try a differ charger to see if that works and if you can try to replace the battery and see if that makes a difference. i hope this helps and good luck on your issue
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,215
