Ga door naar hoofdinhoud
The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
6 Vragen Bekijk alle
Vraag afgerond
Can't close battery cover, because of small plastic broke
So this little plastic hole just broke, don't know how to repair that. It's annoying, because for this time I'm using ducktape, but it's not practical, when you need to pull of sd card.
Is dit een goede vraag?
1 Opmerking:
Are you referring to the clasp that holds the battery cover down?
door
Voeg een opmerking toe
2 Antwoorden
Hi. Probaly u will need to replace entire housing of camera.
Was dit antwoord nuttig?
Do you have the little plastic hole with you? If you do then super glue it back on.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 176
