Ga door naar hoofdinhoud
Reparatiegidsen voor de MacBook Air, de huidige lijn consumentenlaptops van Apple.
4822 Vragen Bekijk alle
Re-connecting fan ribbon cable
I am trying to install a new fan but the ribbon cable is so small and flexible, I can't insert it into the ZIF socket.
Any suggestions?
Thanks
Update (08/27/2018)
I tried to do this and ended up breaking the latch while trying to pull the ribbon cable through the opening. Not happy about the result, although I think I have found a work-around
Is dit een goede vraag?
1 Opmerking
Sorry to hear you have broken the latch.
You’ll need to get a new base connector and carefully snap it out and replace your broken latch unless you broke the connector body side in which case you’ll need to get some one with good micro soldering skills to replace the full connector.
Haven’t had any luck with work-arounds - Sorry
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Get some electrical tape and cut it down the the width of the ribbon cable fold over one end to create a pull tab. Now place the tape onto the ribbon to give your self something to pull either in or out as needed. Then you can peel off the tape.
Don't forget the unlatch the connector first!
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Close the latch after the cable is fully inserted to lock it in place.
door
Voeg je antwoord toe
Steve B zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 20
Altijd: 754
