Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Powers up, then shuts down
Hi there guys
I have here an iPhone 5S that does something rather strange. I have recently refurbed the whole phone with new components, inc battery and screen.
The phone powers up, shows the Apple symbol for about 2 seconds then the screen goes blank, however you are able to see the lit up backlight. It stays on for about 15 seconds then shuts down, any ideas of what it could be?
Regards
Fonebitz
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Issue was it just need to be restored through DFU Mode
Was dit antwoord nuttig?
Try resetting your screen cables connectors and do not have the shield cover for the screen connectors and see if it reboots.
1 Opmerking:
Done all the obvious, but still nothing
door
Are you 100% sure all the screws are in the proper holes on the lcd/digitizer bracket? If one of the slightly longer screws is put in the lower right hand screw hole, you could possibly damage your board or put pressure on the board until it behaves the way you are explaining. I have seen this happen personally. I would remove the screws and that bracket. Then Id test it out.
2 opmerkingen:
I powered on the phone without the Connector bracket to test it and still the same, I also did it with the bracket and correct screws (checked 3 times) and no change
door
Do you still have the old battery? I have seen bad batteries (even new) cause iPhones to act crazy. Its worth a shot.
door
Voeg je antwoord toe
fonebitzltd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 98
