Ga door naar hoofdinhoud
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
247 Vragen Bekijk alle
Can I use a hot glue gun to remove the screen?
Hi! I'm repairing the screen of my galaxy note 3(just the glass) and have heard that I need a blow dryer or heat gun to melt the glue and remove the glass. I don't own any of these and was wondering if I could use the metal tip of a hot glue gun to melt the glue by pressing it up against the phone. Thank you!
Is dit een goede vraag?
1 Opmerking
Definitely not! Hot glue gun is too hot and a point source of heat. Hot air gun will warm the whole are of the screen so causing less stress on the glass. The reason to heat it is to make the glue holding it down will become softer.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Good way to burn the LCD wouldn't try it . you need an even overall heat to soften the glue. tip of a glue gun will just heat the spot you touch.
Was dit antwoord nuttig?
Score 4
Wouldn't recommended it... highly suggest a Heat Gun or Hair Dryer
Score 1
Voeg je antwoord toe
Will Schnall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,379
