Ga door naar hoofdinhoud
Repair information and troubleshooting for the HP Compaq Presario C700. This is a budget laptop made in 2008 as part of the Compaq Presario series of notebook computers.
20 Vragen Bekijk alle
wont power up with power plugged to it
with the power cord plugged in the light around the plug doesnt come and the laptop doesnt come on
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
ok..here it goes for the whole world..
The problem was that PQ1 was bad. Is located next to the PCN1 "where the power jack connects to the motherboard next to the memory". PQ1 is a P-Channel PowerTrench MOSFET P#: FDS6675BZ. you have to replaced it and the problem has to be solved.
one important thing is that if your not qualify to do this kind of job..you have to pay for somebody else to do it...
Was dit antwoord nuttig?
Score 2
DC-Jack needs repair
Score 1
I have a C700 that had this same problem except it was the PQ2 chip. I tried to replace it without success. I had read others having luck just bypassing the chip with a jumper. I tried this and the laptop has been running fine now for a couple of months. I would recommend using the correct replacement if possible.
1 Opmerking:
Kindly define that how and where to place jumper to bypass the chip.
door
Voeg je antwoord toe
mike ward zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 4,410
