Ga door naar hoofdinhoud
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
60 Vragen Bekijk alle
2003 Ford Mustang: Not starting on power
Need help please. I have a Ford Mustang 2003. I have replaced with a new starter, new alternator and new battery. My car still won't start. I also had auto zone check the starter, battery and alternator and they are all working as they should. My car has power until I try to start it, then I have no power at all until I remove the cables from the battery and power is back put still it won't start. If I wait a while it does start. It's driving me crazy..... Please help
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If when it happens, you are sure that you dont have any power then it sounds like a bad electrical connection on the battery circuitry. Such as a bad battery ground, or battery cable connection.
Get a volt meter. Connect the negative directly to the battery post, then start by measuring the battery positive expecting about 12.8V.
Keep the positive terminal on the battery, and move the meter negative cable to the engine block, expecting a good ground there, you should also then see 12.8V or so on the meter.
If not then there is a bad ground, check the battery ground cable to the chassis.
Get a longer grounding wire, such as one jumper cable on the negative battery post. Use it as an extension of the ground so you can use it with your meter to probe the fuse panel in the dash, or relay box under the hood. Still expecting 12.8V or so. If it is good, then the positive battery cable to the fuse box is good.
So from your brief description, sounds like a bad battery ground, or bad connection near the battery.
Next time it occurs, turn on the headlights, and try to wiggle the battery cables. If the headlights turn on, then you found the bad connection.
Was dit antwoord nuttig?
Score 1
Car want say anything want even try to crank
Voeg je antwoord toe
Alfredo Rosas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 36
Altijd: 3,662
