Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Vragen Bekijk alle
What are the possible causes of an overheating CPU and MCP
Hello
After connecting a defective LCD cable on two macbooks A1304 I had no image and the CPU overheats enormously
This cable has probably short circuited a few items ...
After observing the two motherboards I noticed a transistor HS on both the Q9807 serving fueled the backlight
So I replaced these two cards but the problem is always the same :
-No Screen image
-No Startup chime
-The CPU and MCP overheating enormously
As I am not an expert in this field I prefer requested
What are the possible causes of an overheating CPU and MCP after a short circuit ????
thank you in advance for your assistance
Mother board model : 820-2375
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hello,
Tried to make the SMC reset.
https://support.apple.com/en-us/HT201295
Was dit antwoord nuttig?
Score 1
Did you check you fan speeds? Maybe that it destroyed the fan controller on the motherboard
Voeg je antwoord toe
David G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 156
