Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een 15,5 inch convertible laptop met touch screen van Sony.
Flip 15 will not boot - Error code: 0xc000000f
I downgraded from Windows 10 to 8.1 the other day and after rebooting I got the error message below.
'Recovery
Your PC needs to be repaired
The boot configuration date for your PC is missing or contains errors
File \EFI\Microsoft\Boot\BCD
I have tried 8.1 installation media via USB as my Vaio doesn't have an optical drive and each time I got in to it I get that blue screen and when I press refresh or re-install it says "The drive where Windows is installed is locked.Unlock the drive and try again."
What can I do to resolve this? I have tried check disk, tried bootrec but nothing works, any help would be gratefully appreciated.
(If the hard drive needs replacing, what would I need and where do I get it from?)
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Check here this might help: http://www.tomsguide.com/forum/id-185218...
Was dit antwoord nuttig?
Score 1
Pointers to be focus when you encounter this error.
Corrupt boot sector due to power outages, virus/malware infection.Damaged hard disk due to power outages.
Corrupt system files due to improper shutdown and/or power outage.
Damaged Hardware
Check this website for Solutions
https://www.errorsolutions.tech/error/er...
Score 1
Voeg je antwoord toe
Kian O'Donoghue zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 1,213
