Ga door naar hoofdinhoud
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Vragen Bekijk alle
How to check the hard disk cable?
I replaced the original Hitashi hard disk by the Seagate Momentus XT. I tried to clone my already working system with SuperDuper as well as Carbon Copy Cloner. With the both ways the system couldn't boot. A blinking folder icon with question mark was shown instead of the apple logo while booting.. blinking forever. However, I could boot it as external drive, connecting it via USB.. which is a sign that there is something wrong with the connection cable.
I have also tried doing a fresh installation, but also with no hope. The installation was always failed with an error message. However, the installation was completed successfully when I connect it as external.. which is a second sign. Also, I could boot it successfully via USB after the installation completed (still connected as external.) Once I connect it back as internal, the same booting problem happened again (blinking folder icon with question mark, forever.)
I have the feeling that the cable connecting the hard drive to the logic board has a problem. However, I don't want to pay for it before I make sure of that..
Any idea/suggestion is greatly appreciated.
Is dit een goede vraag?
2 opmerkingen
Same here ,, plz help
door
Downgrading the EFI firmware from 1.7 to 1.6 solved my issue. As I remember, the downgrader that I had used with the instructions were posted in a long thread in MacRumors.com forums.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You may have cloned your old drive to a MS-DOS formatted drive or formatted non-GUID. In which case you could read it from an external. I would run disk utilities on it to check the format. If you do need to reformat be sure to set it to one partition and in the options select GUID.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Voeg je antwoord toe
mamoundiraneyya zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,158
