Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Vraag afgerond
Front camera not working after several replacements
Hi there,
I have recently replaced the front camera assembly on an iPhone 5s because the auto brightness feature wasn't working.
However now the camera itself doesn't work.
I have tried resetting the phone, even putting it into DFU mode and updating to the latest iOS, and tried several different camera assemblies - all to no avail.
I can't see any damage at all to the pins on the motherboard where the flex cable attaches, is it still a possibility that this is damaged?
Or is there any other solution that I haven't thought of?
Is it worth disconnecting the battery to power cycle the phone?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
you should disconnect battery before removing front you may have fried the main board with power connected to unit.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Ok thanks Larry, is it likely to sort anything by power cycling the phone now?
door
will never hurt to try I would disconnect for 10 -30 minutes. I had one not come on thought a damaged it but all worked fine after removing battery for hour or more may have been overnight.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 65
