Ga door naar hoofdinhoud
Vraag afgerond
The picture is too large for the screen.
Picture is too large for the screen on my 24 inch television. The picture at sides and top and bottom does not show. Is there any adjustment to correct this problem? jcrews1937@gmail.com
Is dit een goede vraag?
1 Opmerking:
Hi,
What is the 'model' number of your TV? The serial number does not show up.
What is the source of your TV signal? If it is from a set top box or PVR have you got the aspect ratio correct, 4:3 or 16:9 or correct resolution 1080i or 720p? If it is from a TV aerial can you alter the aspect ratio/ display type in the settings area of your TV, or maybe even on your remote is there a display button?
door
Voeg een opmerking toe
1 Antwoord
You may have overscan turned on at the video source, which would result in parts of the picture missing. Check if it is turned on, and if so, turn it off.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,031
