Ga door naar hoofdinhoud
Released by Motorola in November 2004, this stand-alone cable modem allows the user to connect to the internet using ethernet or USB. It features a front panel of indicator LED lights and a standby button on the top of the device.
8 Vragen Bekijk alle
Why are all LEDs flashing?
All LEDs are flashing on my modem and modem does not work. Is there a repair procedure?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I had 2 problems with this modem (SBG6580). Initially it would turn on and all lights would be on and it wouldn't boot. Then a day later the modem lights would blink every other second. I finally found that the problem was the power supply. Replaced it with a new 12v (1.5a) power supply and havent had any issues. Good luck!
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hurray, same problem, same fix!
Thanks! David
door
Brand new MB8611 showed same symptoms, top four LEDs flashing, LAN LED off despite being connected to router. Swapped in a good 12V power supply and everything started working. Big thanks!
door
Maybe you need to run a router-reset or just a simple edit on the router's page.
for a quick solution...
Depending on the model, usually you should follow some basic steps:
1.
Turn off the router.
2.
a. Check for the reset button;
b. Use a bobby-pin or a matchstick and keep it press
3. Power the router while keeping the reset button pressed (5-10 seconds depending on the manufacturer).
4. All the led's should light up and stay lit; after 5-10 seconds, after releasing the reset you should have a factory reset router.
OS
Check that the power supply delivers 12v under load.
Voeg je antwoord toe
mdavi1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 15,007
