Size of logic board in a1151 and a1229 identical?
Can you put the logic board of the a1151 into the a1229's body?
Is dit een goede vraag?
You would need to replace a lot of parts, as the connectors on the A1151 are different from those on the rest of the original 17" MBP models. Also, the keyboard and left I/O board, while identical in form factor, are actually incompatible.
Was dit antwoord nuttig?
Hi Ben
to follow up on the discussion, if I want to change the A1151 board on my MBP by a 1229 (or 1261) board, I will also need to change:
- the left/right fans (or connectors)
- the left/right thermal sensors
- the I/O board
- the keyboard
is there any other parts?
thank you
Then try this one. It says compatible on MacBook Pro 17" Models A1151 A1212 A1229 and A1261
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 14
Altijd: 2,354
