Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
20002 Vragen Bekijk alle
Vraag afgerond
MBP won't power on unless I remove the hard drive
I bought a macbook pro a1286 2010 model and was told it was probably a DC jack issue that caused the computer to not power on.
Just being curious I plugged it in and turned it on, and it worked just fine.
Then I installed a new hard drive and now it won't turn on.
So I replaced the DC jack, still it won't turn on
So I took the hard drive out, and it turns on fine.
That being said, I can't turn the computer off by simply holding down the power button. I have to unplug it for it to turn off
I've installed a new SATA cable to see if that was the issue, and still the computer only powers on without a hard drive installed.
What could be the issue here?
Is dit een goede vraag?
2 opmerkingen
what make and model is your HDD?
door
I've installed multiple just to rule out the hard drive
1 - seagate 320gb
2 - fujitsu 160gb model MHY2160BH
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It was a bad logic board
Was dit antwoord nuttig?
Score 1
1 Opmerking:
So basically you gave up on it.
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 88
