Ga door naar hoofdinhoud
Wheeled toy quadcopter contraption.
Why is my drone not flying?
It starts but won't take off?
It just flips over on the wheels and by itself it just dosent go up?
Is dit een goede vraag?
Score 13
8 opmerkingen
Mine has the same issue, its like the propellers are revered. It wont take off, it will only only push downward into the ground, its unusable!
door
I have the same issue
door
same issue anyone know why?
door
me too it just spins backwards all by itself when you take it off on the weels for a few seconds and i think it has to do with balanced weight but at the moment im still trying to figure out whats wrong
door
door
3 commentaren meer tonen
Voeg een opmerking toe
12 Antwoorden
Het nuttigste antwoord
The proppellers are mounted in the wrong order. Switch left and right propellers front and back. Had the same problem. The drone was pushing down instead of moving up
http://blog.parrot.com/2014/07/24/how-to...
Was dit antwoord nuttig?
Score 6
4 opmerkingen:
Hi thanks God bless you it works i thought my new drone was spoilt i came here read your started my drone and it came i recommend this to everyone IT WORKS
door
hello, thank you your suggestion works
door
Thanks a ton! UDAMAN
door
Top man. It's working now :)
door
Two propellers angle up and two angle down. Align then in a cross cross pattern so:
front left angle up - front right angle down
back left angle down - back right angle up
Score 4
3 opmerkingen:
Thank you so much. This is exactly right!
door
OMG this was helpful!!! Thank you!!!
door
Thanks it works perfectly
door
Keep switching the propellers and trying it until you get the correct order
Score 2
1 Opmerking:
ok thank you
door
But I figured it out one of your PROPELLERS might be WEAKER than the other ones allowing it to be UN-EVEN. For mines that's what it is but I might need to buy new propellers if you can do that
1 Opmerking:
i bought new propellers it still doesn't work
door
yes thats all it does and dont come off the grown just flips foward
My drone typhoon h is not responding to the monitor
My typhoon h drone camera is nor responding to the monitor
No.it goes on it's side. And doesn't fly. It's not mine. It's a friends drone I was using
The wings are rotating but it doesnt fly
I had the same problem. I had to put the propellers on again after a crash and I just installed them on the wrong motor. Once in the right position it works like it’s supposed to. Good Luck!
Check the direction of the props. They might have gotten reversed and the 2 same angle props go diagonally to each other
if you press the takeoff button then try lifting up it should work
1 Opmerking:
my parrot rolling spider never failed so theirs should be a priority
door
Voeg je antwoord toe
Isaac Papasidero zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 74
Altijd: 18,365
