Ga door naar hoofdinhoud
The HMDX Jam Plus is a portable Bluetooth speaker. This speaker can be used by itself or paired with another Jam Plus for stereo audio.
7 Vragen Bekijk alle
My HMDX Jam Plus won't turn on. How do I fix this?
I left the speaker plugged in overnight but I still won't power on. When I plug it in the charging light doesn't light up.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Have you tried a different charger? You can use a USB cable to connect between the speaker and a working PC and see if the charging light in the speaker turns on. If it does the charger is faulty. If not, first try a different USB cable, in case the first one (if you used the one from the power adapter) is faulty. If the light still doesn't come on, you either have a faulty charge circuit in the speaker or a faulty battery
Was dit antwoord nuttig?
Score 2
Replace batt... http://ugemrp.com/1066/0000/0014/0066/00...
Voeg je antwoord toe
Maxwell Erickson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 7,316
