Ga door naar hoofdinhoud
The Nokia N70 It is equipped with a 2 megapixel camera with built-in flash, a front VGA camera to allow video calling, FM radio, and Bluetooth.
9 Vragen Bekijk alle
My n 70 nokia phone signal is not working
my n 70 nokia phone signal is not working
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi,
Please try the following ways.
1) Go to settings --> network and select manual option and see if its showing any other networks. If you can find your network just select it and you will be connected.
2) if not you can try to remove the sim wipe it and put it back again see it works.
if it still doesn't work, you can contact your telecommunication service provider. They will help you.
Regards
Abdul
Was dit antwoord nuttig?
Score 2
1 Opmerking:
simcard not valid
door
Please make sure your carrier supports this phone.
The Nokia N70 only supports
2g 900, 1800, 1900 MHz
3g 2100 MHz
Voeg je antwoord toe
JIN P L zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 804
