Ga door naar hoofdinhoud
Een spelcomputer die in 1985 door Nintendo in Noord-Amerika werd uitgebracht, genaamd het Nintendo Entertainment System, model NES-001.
No Image on TV and blinking light
Hi there! I bought a NES that doesnt work.. When i plug her on the TV, the light start blinking and no image appears on the TV, the image is the same as i didint have plugged the console.
Do you know what is wrong with the console? I tried different TV outputs and cleaning the cartridge reader.
Thanks in advance!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Best bet is to take the NES Console apart, neatly and replace the 72-Pin connector. This will solve the problem 99.99% of the time.
Was dit antwoord nuttig?
Hello. You have what may be a broken 72 Pin Connector. You May want to get a new one or it may be dirty so just clean it. The Game may be dirty too. Cut off the green part of a sponge or get scrub pads from the store too clean your pins. If it does not work, Open your cartridge and clean the pins well with a small ammount of counter top cleaner. brish it on and then take a towl and wipe the cleaner off. Then put the case back on. Please only do this with the game.
Voeg je antwoord toe
Daniel Reis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,342
