Ga door naar hoofdinhoud
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Vragen Bekijk alle
Weak light in the display
I recently changed the LCD screen of my iPad because it was broken. When I finished I turned on but the light is too weak and I can´t use it. A technician said that it should be the display, but my question is, how do it know if it´s the display or only the cable?
http://www.amazon.de/LCD-Flex-Kabel-f%C3...
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The display should have come with a new cable. I would return it for an exchange
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
No sorry, you missunderstood it. I changed the LCD screen but the light in the display is too weak, so a technician says that I have to change the display (under the LCD screen). But I don´t know if it is enough changing the cable of the display or I should changed all the display, because the difference of prices is quite big
door
Sounds like there's a weak backlight in the display you've gotten. I understand the value of saving money. However, you're more than likely going to have issues like this, if you don't buy quality parts. You're more than likely going to have some problems
door
The touch screen I bought it in this website and it looks fine, but maybe I damaged something in the display beneath and when I turned it on the light was too weak. The problem now is the display, and I am not sure is the problem is in the display, the cable of the display or somewhere else
door
It is very possible that you damaged something during the repair. I would either return the product or purchase a product that has the cable on it. I understand at frustrating spending money. But, it's even more frustrating not having your device work
iPad 2 LCD
door
Bad LCD or backlight.
Most likely a defective LCD or the backlight went out when attempting the repair due to the device being on while worked on.
Voeg je antwoord toe
Ricardo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 94
