What to do when I want to factory reset my phone
I wanted to factory reset my phone vut i accidentally clicked the adb and now it wont get off the screen what do i do know or how do i factory reset my phone
Is dit een goede vraag?
WARNING ! Hard Reset will erase all of your data
All described operations you are doing at your own risk.
Hard Reset ZTE Blade III
First method:
Start by holding down the Power key in order to switch off the device.
Then press and hold Volume Up + Power button for a couple of seconds.
You can release held keys when you see an Andoid image.
In order to open the Recovery Mode hold down the Power key for a short while.
Choose "wipe data/factory reset" by using Volume buttons to navigate and Power button to confirm.
Afterwards select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
To restart the phone, choose "reboot system now".
Success! The hard reset has just been performed.
Second method:
At first, turn on the phone by using the Power button.
After pressing the Home button go to Settings and then to Backup & Reset.
Choose the Factory Data Reset.
In the next step tap Reset Phone.
Select Erase Everything if you are sure you want to clear all your data.
Well done! Your phone is ready to use.
Was dit antwoord nuttig?
ok but now its asking to put my google acount that sync it to before i reset ,,but i cant remember what do i do now????
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,572
