Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
20 Vragen Bekijk alle
Vraag afgerond
No data sync and no charge
Hello
I replaced the lock flex cable on my iphone 5s. When I was done I had to hard reset the phone in order for it to boot, it wouldn't boot without it.
Now I found out that the battery will not charge, or when I connect it to my pc it won't show up on itunes and my pc doesn't even find it.
I have already replaced the dock connector and the headphone jack and home button still work.
Hope someone can help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It sounds like it may be a bad U2 Charging IC.
Was dit antwoord nuttig?
2 opmerkingen:
I also have that thought but it can't be broken because I replaced the lock flex. It worked fine before I replaced it.
door
If iTunes won't detect it , then it points more to the dock connector. Did you inspect the dock connector on the PCB for damaged pins?
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 84
