Not powering up after liquid spill
The other night, some wine got spilled on my MBA. Unfortunately my wife tried to turn it back on after wiping off the spill and kept it plugged in when it didn't work.
I followed directions I found here on removing and cleaning the inside completely with ip alcohol. I didn't see any sign of corrosion or damage to any of the parts.
After letting everything dry, the MBA still does not power up at all and the mag safe light does not come on at all either when plugged in.
Any idea what I should do next? Could it be a short in the mag safe plug or the io board? I don't want to spend a whole bunch of money replacing parts without knowing the problem.
Thanks for your help!
Is dit een goede vraag?
1 Opmerking
To help determine the problem in this situation, should the MBA power up without the keyboard/trackpad cable plugged in? Does power up require the SSD to be plugged in?
door David Reinhardt
