Ga door naar hoofdinhoud
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Vragen Bekijk alle
How to remove broken screw
How can I remove a screw when it is rounded by the screwdriver and the screwdriver does not fit anymore? The screw is a 3.2 mm Phillips screw to atach the fan. Who knows how to solve this problem?
In Dutch:
Hoe kan ik een schroef verwijderen wanneer deze is afgerond en de schroevendraaier niet meer past? Het gaat om een 3,2mm Philips schroef voor het vastmaken van de fan.
Weet iemand hoe dit opgelost kan worden?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Use a Dremel tool and cut a flat head notch across the head.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you, Mayer. Good idea! But because I don't have a Dremel, I decide to bore out the screw. I succeded doing so, but only later on it will be clear if this method is a good one.
door
I have use the method mayer described and it works well but if you don't have a Dremel tool you can try an old screw driver with a touch of super glue make sure it sets up first and make sure none gets into the threads or your done. But try mayers idea first its safer
Score 2
4 opmerkingen:
Thank you, Jim. I already made a hole in the screw and I could remove the fan.
door
Jim, please explain what the super glue is supposed to do and where to apply it on the screwdriver
door
just the smallest amount on the tip of the screw driver and then touch it to the screw making sure you do not get any on the case or over into the threads or this will lock everything tight. wait for it to dry .when dry use downward pressure and turn out screw
door
How to obtain new screws? Also the screws that support a 2,5" SSD
door
Voeg je antwoord toe
Theo Poggemeier zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 148
