Ga door naar hoofdinhoud
Model A1320 / 8 or 16 GB capacity
156 Vragen Bekijk alle
My iPod screen is turning white is this fixable?
the Ipod felt on the floor and when I plugged it in too my computer the screen turns white... everything is working only I can't see what is playing and i can't choose a number because the screen is always white. is this fixable by myself??
Is dit een goede vraag?
Score -1
1 Opmerking
I noticed you never got an answer to this. Are you still having this problem?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
The iPod has a liquid crystal display. A very thin capsule with a chemical compound which builds up the picture under an electrical charge. Likely is this capsule ruptured as a result of the fall.
There will no longer be any picture or pattern. All you are seeing is the electroluminescent screen (backlight) which shines through the crystals in the display.
This must be replaced as a complete unit. Relatively easy on the 4th gen nano.
The contents of the display are regarded as toxic so take precautions if you see any of this inside. Mop up carefully with camera lens tissues.
After plugging in the replacement give it a quick try before pushing it all back into place.
Was dit antwoord nuttig?
Score 1
if i don't have a replacement for it can't i be give any other sol'n to solve this problem
Voeg je antwoord toe
sam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 2,025
