Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Vraag afgerond
How to unscrew one of the screws in an iPhone 5
So I have an Iphone 5 here which has water damage and I plan to soak the logic board in alcohol but i have encountered a problem. You see one of the screws to the right side of the battery. The one in which has a hole in it to screw in the shielding for the battery port. Is giving me trouble because I can't unscrew it. I'm using one of the mini flat head screwdrivers but it still won't budge. Please help
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
it should work with a small flat head screwdriver...
Was dit antwoord nuttig?
I would use a 2mm slotted driver. Be careful not to scratch the board when removing it, it might give you some resistance but it shouldnt be too hard to remove!
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 102
