Ga door naar hoofdinhoud
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Vragen Bekijk alle
Vraag afgerond
Screen Backlight behaving strangely after minor soda spill?
I spilled soda on my macbook pro 13" late 2013. The screen backlight started to acts nuts, It decides to turn on and off by itself. Most often, however, it is not working- But when it turns on, it stays on until I close the lid or restart the device. I have no Idea how to fix it myself. Also, in my country no one is using or fixing Macs, so can't get some one to fix it.
What do you think the issue is knowing that its been 5 months and no improvement.
P.S. Apple says you need everything new inside the macbook pro(That when I was abroad ). The repair price is close to a brand new one. I have been using it connected to a monitor for the the time the screen backlight is off and when it gets resurrected I use it as normal laptop with a shiny retina screen.
Is dit een goede vraag?
2 opmerkingen
I just received a new logic board from iFixit, and I installed it on the the macbook. Everything works fine now, thank you iFixit.
door
AWESOME! Good job.
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Hi there, Sounds like the backlight has been damaged. It is located under the keyboard and can be replaced with out having to remove the keyboard. It is quite a technical repair though requiring you to remove the motherboard. The part is not to expensive to buy, just requires a bit of computer dismantling knowledge.
Good Luck
Was dit antwoord nuttig?
Score 1
1 Opmerking:
My issue is the screen backlight not the keyboard. If you got it right, what exactly does it look like in order to change it and get the screen lights to work.
door
Have you tried disassembling it, drying it out, and cleaning up the dried soda/syrup? I'm thinking the culprit might be an intermittent short occurring.
1 Opmerking:
Yes, I have cleaned and dryed the liquid.
door
Post some pics of the board and by the lcd connector too.
2 opmerkingen:
Will be posting picture shortly
door
Posted above
door
I think there's corrosion on the lcd board you will need to remove the clutch cover to expose it.
2 opmerkingen:
I did that already and its clear.
door
Just replace the lcd flex cable then
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 141
