Ga door naar hoofdinhoud
The Airport Time Capsule is a wireless router and network-attached storage (NAS) device manufactured by Apple. Model A1409 is the fourth generation revision of the Time Capsule released in June 2011.
25 Vragen Bekijk alle
Vraag afgerond
time capsule power supply compatibility
TC works just fine , but the hdd is not spinning up .tried another hdd and same thing . used an external power supply to hdd and worked , The PSU model# for mine is 614-0464 , will a PSU from an older one work in it .i have found model # 614-0440 .the PSU for mine does not exist i guess...
Is dit een goede vraag?
1 Opmerking
Hi Travis,
Did you find the answer to your question?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
i had taken a shot in the dark and ordered a power supply 614-0412 and they shipped me 614-0440 i said screw it i will try it and it has been working just fine . The power supply that came with it was 614-0464 and that power supply is non-existent . So to answer my own question older power supplies will work in newer models . My model is md032ll/a (2011) . it had the updated power supply that didn't die as quickly unlike the old ones ,now it has the older power supply that had the problems but thats better than not working at all and for 20$ you can't beat the price.
Was dit antwoord nuttig?
Score 2
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 664
