Ga door naar hoofdinhoud
De TDK Trek Max is een draagbare draadloze speaker met Bluetooth-functionaliteit. Dankzij de ingebouwde microfoon kan de speaker als handsfree-set fungeren voor elk apparaat dat via Bluetooth met de speaker is verbonden of er fysiek op is aangesloten. De aux- en USB-poorten maken de speaker compatibel met vrijwel elk apparaat.
Why won't my speaker turn on?
I have had the device plugged in all day and it still won't turn on. My brother has the same speaker and uses my charger so I know that is not the problem. I'm thinking the battery is dead or maybe the charge port is malfunctioning. What can I do?
Is dit een goede vraag?
Score 4
1 Opmerking
I saw you mentioned the sound was low on this speaker in another thread, did you get the power issue resolved then?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
If the speaker is not turning on after a full charge it could be suffering from a battery malfunction. Follow our guide on battery replacement to fix this issue.
Was dit antwoord nuttig?
Score 1
Trek max will work even without a battery connected. (power supply must be connected). I have one that works only when fully charged for a short time unless charger plugged in. This indicates a problem with battery voltage sensor. Same battery works fine in another unit. Your problem may be a worse case of this. I suggest Remove battery and test it.
1 Opmerking:
My Trek Max A34 will not charge. I thought it was the battery so I boughf a new one. That won’t charge either. Only way Trek Max will work is plugged in. How do I fix this issue?
door
Jag får inget ljud i högtalarna
Voeg je antwoord toe
Rebecca zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 4,320
