Ga door naar hoofdinhoud
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 Vragen Bekijk alle
What "system" has stopped & can I fix it?
Keeps coming up with :
Unfortunately, system has stopped.
OK
It seems to have added a multitude of games or something. ..some of it looks like !!%@ ....I can't remove anything ...... been trying for 3 days now . I'm terribly technically illerate which doesn't help.
Anyone ?????? Pleeeeeeeassse? ???
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
It seems as though malware has taken over your Tab.
Can you operate the Tab at all?
If so try to download, install and run the following:
https://play.google.com/store/apps/detai...
It will check for and remove malware from your Tab. Hopefully this may solve your problem.
If you cannot get to do this try the following:
Before attempting the following ensure that your Tab's battery is fully charged.
You will have to perform a hard reset.
Hard Reset
Warning : Your Tablet will be reset back to factory default, you will lose all user downloaded apps and user data - it will be like when you first bought it.
Ensure the Tab is OFF, then
Press and hold the Volume up button then press and hold the Power button. (two buttons held on together)
When the Samsung logo appears, release all.
Select wipe data/factory reset. (Use the Volume buttons to highlight and the Power button to select.)
Select Yes -- delete all user data. (Use the Volume buttons to highlight and the Power button to select.)
Select reboot system now. (Use the Volume buttons to highlight and the Power button to select.)
Allow several minutes for the reboot process to complete.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
i have this problem too. i already did the factory reset, but "system has stopped" still showing.
door
Hi, Hjay Red,
Try reinstalling the firmware. http://www.samsung.com/ca/support/skp/fa...
door
I'm having the same problem too, I tried the reset but seems like there are so many "Unfortunately stopped errors"
door
Voeg je antwoord toe
heathercc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,767
