Ga door naar hoofdinhoud
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
166 Vragen Bekijk alle
Wireless module stripped screw issue.
Hi!
It seems that the wireless module has been really overly fastened on my device and I'm having a really hard time with it.
One screw got loose eventually, but the other just do not want to budge.
The real problem is that it got pretty badly stripped during my attempts.
Stripped Screw
Is there anything I could do to get this thing to move, or am I screwed (I know...)?
Thanks!
Is dit een goede vraag?
Score 3
1 Opmerking
hey chan, did you fix it? cause i got kinda the same problem (both of the screws are damaged on top) and i cant manage to get them out
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hello, your not the first and definitely wont be the last screw, screw up. : )
I would first try tapping very gently a straight bladed screw driver into the old hex hole , with a thin blade just a bit wider than your stripped hex. Until you get a good bite to start removing the screw. You will have more torque force with a straight blade then with the hex and may also loosen the screw by the tapping action.
By chance that doesn't work for you , you can try to get a bite of the outside screw head with a pair of small duck bill or flat nose mini pliers with teeth. Or a pair of the ifixit screw extracting pliers.Screw Extracting Pliers
I would go nose down onto board(its only contact with a ground plain) squeeze screw head and turn.
Only if all else fails would i think of drilling or cutting out.
Hope this helps and good luck.
Clyde
Screw Extracting Pliers Afbeelding
Product
$19.99
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I have the same problem and the Pliers works like a charm. Just be careful the plier might break your wireless module. Mine was scratch a little bit but luckily it still works though.
https://i.imgur.com/OV67bVg.jpg
door
if you have a dremmel with the proper head piece (correct terminology?) you can make a clean cut all the way through the screw and use a flathead screwdriver to remove it. just be careful not to harm the board at all.
edit: I should clarify, when I say all the way through I mean the top rounded part of the screw of course.
Voeg je antwoord toe
Chen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 1,347
