Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
MacBook Pro will only work in guest account
So after a liquid spill, a keyboard replacement, logic board cleaning, and main disk repair via Disk utility, I can still only use my laptop with the guest account, otherwise it shuts off at the Apple logo after showing a status bar that fills up a bit. It also shuts off before I can run AHT. When I manged to get into disk utility, my usual disk "Macintosh HD" was greyed out so I couldn't verify it.
Should I give up and get the board repaired or is there a chance this is a hard drive issue?
Thanks!
Is dit een goede vraag?
Score 3
3 opmerkingen
Same thing is happening to me. How did you fix it?
door
Angela, we're working on it. What's your exact model? Did you get anywhere with this?
door
How did you fix it? I have the same problem
door
Voeg een opmerking toe
3 Antwoorden
I would disconnect the internal hard drive and boot from an external. This sounds to me like a hard drive/ IR cable issue.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
The plot thickens! While trying to do this, I keep getting the 3 beep RAM warning which keeps me from going any further. Arrgh! I have reseated them several times but to no avail. Could I have damaged them?
door
@mayer I checked the schematics, can probably be figured out; specially for liquid damaged boards. Then again, no two boards fail the same from liquid damage, so we can never tell for sure if we will be successful.
So far, I've had extremely high rate of success with liquid damage repair.
door
Het nuttigste antwoord
Sounds like you have a Malware infection in that users account.
Have you tried booting up under an external drive and run both Disk Utility to check the drives permissions (do the disk repair as well) as well as run a good antivirus/malware program.
If you still can't get the account to work you'll need to backup your data (after booting up under the external drive) then deleting the user account and creating a new one. I would recommend you also create a second admin level account to have for the next time. If you had it you could have tried it.
Score 3
Have you try going to safe mode? what happens
1 Opmerking:
Still shuts off before going to safe mode :(
Stayed on fine in guest account and Disk Utility.
door
Voeg je antwoord toe
ingwis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 8,244
