Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Vragen Bekijk alle
acts lilke the earphones are plugged in when they are not
My original iPhone has recently started acting like I have my earphones plugged in and gives a message:this accessory does not work with this iphone. turn on airplane mode or off not sure.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
check inside the jack for dust which might be tricking iphone to think headphones are inserted. you can remove this with toothpick or small tweezers.
Was dit antwoord nuttig?
Score 1
Plug an unplug the headphones a couple of times realy fast, it's fixed it for me in the past
Cut the fuzzy part off a Q-tip & use the stem to clean out the headphone receptacle. Works better than a toothpick, and was able to fix my phone this way.
1 Opmerking:
Thanx that helped the little symbal went away and i jus went and check and my sound works again... Thank you so much your answer was awessssooooome
door
Voeg je antwoord toe
Bobbie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 4,448
