Ga door naar hoofdinhoud
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Vragen Bekijk alle
Water out the steamer when brewing
We cleaned the brewing line but still have some water coming out the steamer during brewing, as if a valve or seal is not working. Any ideas? Starbucks apparently doesn't make these Espresso Makers or provide customer service anymore.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Refrence the Starbucks Barista teardown to get inside of the machine. At step 8, loosen the 2mm hex screw on the steam valve knob and you should be able tighten/close the steam knob more than before. Re-tighten the 2mm hex screw, reassemble the machine and test it. If this doesn't solve the problem you may have some calcium blocking the valve from closing all the way, which a descale should take care of.
Was dit antwoord nuttig?
Score 1
See the answer for leaking steam wand o-ring replacement.
Voeg je antwoord toe
Tim Kingan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,953
